Ir para o conteúdo principal
Sony DVP-SR200P DVD Reader Replacement
O que você precisa
  1. Sony DVP-SR200P DVD Reader Replacement, Top Cover: passo 1, imagem 1 %32 Sony DVP-SR200P DVD Reader Replacement, Top Cover: passo 1, imagem 2 %32
    • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
    • One 3/16" screw on the right side of the DVD player.
    • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
    • Three 3/16" screws on the back of the DVD player.
  2. Sony DVP-SR200P DVD Reader Replacement: passo 2, imagem 1 %32 Sony DVP-SR200P DVD Reader Replacement: passo 2, imagem 2 %32
    • Slide the cover away from the front of the DVD player until it is off.
  3. Sony DVP-SR200P DVD Reader Replacement, Processing Board: passo 3, imagem 1 %32
    • Remove the blue tape from the processing board by gently pulling upward.
  4. Sony DVP-SR200P DVD Reader Replacement: passo 4, imagem 1 %32 Sony DVP-SR200P DVD Reader Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
    • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
  5. Sony DVP-SR200P DVD Reader Replacement: passo 5, imagem 1 %32
    • Handle the processing board with care. It is fragile.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
  6. Sony DVP-SR200P DVD Reader Replacement: passo 6, imagem 1 %32
    • Orient the DVD player so that you are facing the video and audio jacks.
    • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
    • The processing board is now free to be removed and replaced.
  7. Sony DVP-SR200P DVD Reader Replacement, DVD Drive: passo 7, imagem 1 %32
    • Orient the DVD player so the front of the DVD player is opposite of you.
    • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
  8. Sony DVP-SR200P DVD Reader Replacement: passo 8, imagem 1 %32
    • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
  9. Sony DVP-SR200P DVD Reader Replacement, DVD Reader: passo 9, imagem 1 %32 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: passo 9, imagem 2 %32 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: passo 9, imagem 3 %32
    • Flip the DVD drive upside down, to match the orientation of the first picture.
    • Carefully remove the white ribbon cable from the brace holding it in place by sliding it out towards you.
    • Next remove the brace from the DVD drive. Carefully wiggle and pull the brace upward as the white ribbon cable slides out through the brace.
  10. Sony DVP-SR200P DVD Reader Replacement: passo 10, imagem 1 %32
    • Remove the four silver #1 Phillips 3/16''screws to free the DVD reader from the DVD drive.
  11. Sony DVP-SR200P DVD Reader Replacement: passo 11, imagem 1 %32
    • Remove the DVD reader from the DVD drive by pulling it upwards off of the drive.
    • The DVD reader can now be replaced.
Conclusão
3 outras pessoas executaram este guia.
Jose Coronel
Membro desde: 01/11/13
84 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-17, Forte Winter 2013 Membro de Cal Poly, Team 5-17, Forte Winter 2013
CPSU-FORTE-W13S5G17
5 Membros
Autoria de 6 guias
1Comentário do guia
Which part help to play games in dvd player
WWE Final Fighters - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 29
Últimos 30 dias: 67
Ao todo: 5,417
