Ir para o conteúdo principal
Sony DVP-NS325 Optical Drive Replacement
O que você precisa
  1. Sony DVP-NS325 Optical Drive Replacement, Outer Case: passo 1, imagem 1 %32 Sony DVP-NS325 Optical Drive Replacement, Outer Case: passo 1, imagem 2 %32 Sony DVP-NS325 Optical Drive Replacement, Outer Case: passo 1, imagem 3 %32
    • Use a Phillips screwdriver to unscrew the five screws.
  2. Sony DVP-NS325 Optical Drive Replacement: passo 2, imagem 1 %32 Sony DVP-NS325 Optical Drive Replacement: passo 2, imagem 2 %32 Sony DVP-NS325 Optical Drive Replacement: passo 2, imagem 3 %32
    • Use the Philips screwdriver to remove the screws located on the sides and the back.
    • Not shown are the right side screw and the middle screw.
  3. Sony DVP-NS325 Optical Drive Replacement: passo 3, imagem 1 %32
    • Use a spudger to separate the case from the chassis.
    • Remove the case.
  4. Sony DVP-NS325 Optical Drive Replacement, Optical Drive: passo 4, imagem 1 %32 Sony DVP-NS325 Optical Drive Replacement, Optical Drive: passo 4, imagem 2 %32 Sony DVP-NS325 Optical Drive Replacement, Optical Drive: passo 4, imagem 3 %32
    • The Location of the three screws holding the CD reader in place.
  5. Sony DVP-NS325 Optical Drive Replacement: passo 5, imagem 1 %32
    • Use a Phillips screwdriver to remove all three screws holding the CD reader in position.
    • Two screws not shown.
  6. Sony DVP-NS325 Optical Drive Replacement: passo 6, imagem 1 %32 Sony DVP-NS325 Optical Drive Replacement: passo 6, imagem 2 %32
    • Disconnect all of the optical drive motherboard connections.
  7. Sony DVP-NS325 Optical Drive Replacement: passo 7, imagem 1 %32 Sony DVP-NS325 Optical Drive Replacement: passo 7, imagem 2 %32 Sony DVP-NS325 Optical Drive Replacement: passo 7, imagem 3 %32
    • Lift the four retention clips holding the face of the DVD player in place.
    • Two clips are not shown, left and bottom right side clips.
  8. Sony DVP-NS325 Optical Drive Replacement: passo 8, imagem 1 %32
    • Remove the front face of the DVD player by pulling it away from the device.
  9. Sony DVP-NS325 Optical Drive Replacement: passo 9, imagem 1 %32
    • Remove the optical drive.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Ao todo: 300
