Introdução
When the DVD tray of your DVD player won't open anymore it is likely that this is caused by a defective motor. It is just plain waste to throw away your DVD player and buy a new one, just because of one broken part. This guide will show you that it is really easy to replace the broken motor so you can keep using your device. You will just need some basic tools, a soldering iron and the spare motor, as listed above.
O que você precisa
Unplug the DVD player from the wall socket.
Locate the five 7mm Phillips screws holding the top panel in place, of which three are located on the back panel, and one is located on each side.
Unscrew the five screws using the #2 Phillips screwdriver.
Turn the device upside down, with the front of the device facing towards you.
Locate the black sleeve that covers the opening mechanism.
Using the flathead screwdriver, move the slider (located underneath the sleeve, as seen in the first photo) to the right, so that the DVD tray slides open.
Put the DVD tray assembly in front of you with the DVD tray facing towards you.
Slide the DVD tray as far out of the device until it is restricted of going further by two clips on the sides of the DVD tray.
Push the two clips to the outside of the DVD tray assembly so that the DVD tray can slide past them.
Remove the DVD tray from the DVD tray assembly, by horizontally sliding it completely out of the DVD tray assembly.
3 outras pessoas executaram este guia.
