Pular para o conteúdo principal
Introdução
If the device is on but nothing shows up on the screen, the screen may need to be replaced.
Peças
Nenhum componente especificado.
  1. Use your hand to remove the small back cover. Use your hand to remove the small back cover.
    • Use your hand to remove the small back cover.
  2. Remove the two 0.473" pan head screws.
    • Remove the two 0.473" pan head screws.
  3. The screen should now detach from the main device.
    • The screen should now detach from the main device.
    • The screen will still be connected by the wires.
  4. Remove the wires attached to the white base by using the tweezers. Remove the wires attached to the white base by using the tweezers.
    • Remove the wires attached to the white base by using the tweezers.
  5. Do the same with the wires attached to the black base. Do the same with the wires attached to the black base.
    • Do the same with the wires attached to the black base.
  6. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  7. The screen should now be completely separated from the main device.
    • The screen should now be completely separated from the main device.
  8. Remove the four rubber feet and the screws beneath.
    • Remove the four rubber feet and the screws beneath.
    • Remove the two exposed screws on the left side.
    • Pull back the cables until the screw is visible.
  9. Using the spudger, separate the top and bottom covers.
    • Using the spudger, separate the top and bottom covers.
  10. Identify the gray back of the screen.
    • Identify the gray back of the screen.
  11. Remove the screws.
    • Remove the screws.
  12. Remove the metal plates.
    • Remove the metal plates.
  13. Using spudger, push the lock clips to unlock the ribbon cable. Using tweezers, pull the connector loose.
    • Using spudger, push the lock clips to unlock the ribbon cable.
    • Using tweezers, pull the connector loose.
  14. Place your hand on the front of the screen and push upwards. Place your hand on the front of the screen and push upwards.
    • Place your hand on the front of the screen and push upwards.
Conclusão
2 outras pessoas concluíram este guia.
Oliver Woolsoncroft
Membro desde: 20-01-2012
69 reputação
2 Guias de autoria
Equipe
Cal Poly, Team 11-21, Maness Winter 2012 Membro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 Membros
5 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Todo: 2,264
