Ir para o conteúdo principal
Sony DVP-FX730 Monitor Replacement
O que você precisa
  1. Sony DVP-FX730 Monitor Replacement, Cover: passo 1, imagem 1 %32
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Monitor Replacement: passo 2, imagem 1 %32
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Monitor Replacement: passo 3, imagem 1 %32
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Monitor Replacement: passo 4, imagem 1 %32
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Monitor Replacement, Monitor: passo 5, imagem 1 %32 Sony DVP-FX730 Monitor Replacement, Monitor: passo 5, imagem 2 %32
    • Use your hand to remove the small back cover by gently pulling upward.
  6. Sony DVP-FX730 Monitor Replacement: passo 6, imagem 1 %32
    • Using a screwdriver, remove the two 12 mm pan head screws.
  7. Sony DVP-FX730 Monitor Replacement: passo 7, imagem 1 %32
    • The screen should now detach from the primary device.
    • The wires, indicated with a blue box, will still connect the screen.
  8. Sony DVP-FX730 Monitor Replacement: passo 8, imagem 1 %32 Sony DVP-FX730 Monitor Replacement: passo 8, imagem 2 %32
    • Remove the wires attached to the white base using tweezers to pull them up.
  9. Sony DVP-FX730 Monitor Replacement: passo 9, imagem 1 %32 Sony DVP-FX730 Monitor Replacement: passo 9, imagem 2 %32
    • Referring back to Step 8, do the same with the wires attached to the black base.
  10. Sony DVP-FX730 Monitor Replacement: passo 10, imagem 1 %32
    • The screen should now be completely separated from the main device.
Conclusão
Andrew Ward
Membro desde: 01/20/12
93 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-21, Maness Winter 2012 Membro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 3,027
