Ir para o conteúdo principal
Sony DVP-FX730 Laser Replacement
O que você precisa
  1. Sony DVP-FX730 Laser Replacement, Cover: passo 1, imagem 1 %32
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Laser Replacement: passo 2, imagem 1 %32
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Laser Replacement: passo 3, imagem 1 %32
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Laser Replacement: passo 4, imagem 1 %32
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
  5. Sony DVP-FX730 Laser Replacement, Laser: passo 5, imagem 1 %32 Sony DVP-FX730 Laser Replacement, Laser: passo 5, imagem 2 %32
    • Remove the large connector.
    • Remove the small connector.
  6. Sony DVP-FX730 Laser Replacement: passo 6, imagem 1 %32
    • Remove Philips screws with the #0 Philips Screwdriver.
  7. Sony DVP-FX730 Laser Replacement: passo 7, imagem 1 %32
    • Lift up the black piece connected to the wires.
    • Lift gently because the ribbon cable is attached to the bottom.
  8. Sony DVP-FX730 Laser Replacement: passo 8, imagem 1 %32 Sony DVP-FX730 Laser Replacement: passo 8, imagem 2 %32
    • Unlock the lock clip
  9. Sony DVP-FX730 Laser Replacement: passo 9, imagem 1 %32
    • Remove the T6 screws with the T6 screwdriver.
  10. Sony DVP-FX730 Laser Replacement: passo 10, imagem 1 %32
    • Gently pull the rods out with tweezers.
    • Be sure the laser is out of the way so that the rods can be removed.
  11. Sony DVP-FX730 Laser Replacement: passo 11, imagem 1 %32 Sony DVP-FX730 Laser Replacement: passo 11, imagem 2 %32
    • Pull laser off of the rods.
    • Be careful when removing the rods because a fragile metal piece may break.
  12. Sony DVP-FX730 Laser Replacement: passo 12, imagem 1 %32
    • The laser is now removed.
Conclusão
Equipe
Cal Poly, Team 11-21, Maness Winter 2012 Membro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
Membros da 4
Autoria de 5 guias
Um comentário
where do I buy the lens?
mnmmacd - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 39
Duração total: 4,727
