Ir para o conteúdo principal
Sony DVP-FX730 Cover Replacement
O que você precisa
  1. Sony DVP-FX730 Cover Replacement, Cover: passo 1, imagem 1 %32
    • Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath with the Phillips screwdriver.
  2. Sony DVP-FX730 Cover Replacement: passo 2, imagem 1 %32
    • Remove the rubber feet using the spudger.
    • Remove the screws that were covered by the rubber feet.
  3. Sony DVP-FX730 Cover Replacement: passo 3, imagem 1 %32
    • Hold on to the corners of the cover and gently lift the cover.
    • The tray is still connected to the base with wires.
  4. Sony DVP-FX730 Cover Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently remove the wires with tweezers by pulling up on the base they are attached to.
Conclusão
Rogelio Garcia
Membro desde: 01/20/12
19 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 11-21, Maness Winter 2012 Membro de Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 1,464
