Ir para o conteúdo principal
Sony DSC-RX10M3 Back and Right Panel Replacement
O que você precisa
  1. Sony DSC-RX10M3 Back and Right Panel Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
  2. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, imagem 1 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, imagem 2 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 2, imagem 3 %32
    • Remove the battery located at the bottom of the device.
  3. Sony DSC-RX10M3 Back and Right Panel Replacement, Back and Right Panel: passo 3, imagem 1 %32
    • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
  4. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 4, imagem 1 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 4, imagem 2 %32
    • Remove the two 0.7mm screws that secure the right side of the camera.
    • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
  5. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 5, imagem 1 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 5, imagem 2 %32
    • Gently pull off the plastic eye guard.
  6. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 6, imagem 1 %32 Sony DSC-RX10M3 Back and Right Panel Replacement: passo 6, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
    • Use a plastic opening tool to detach the back panel of the camera.
  7. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 7, imagem 1 %32
    • This is a tight spot; make sure you use minimal force when removing the cover.
    • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
  8. Sony DSC-RX10M3 Back and Right Panel Replacement: passo 8, imagem 1 %32
    • This step is only needed if you wish to remove the right side panel.
    • Use a plastic openeing tool to gently detach the right panel.
Conclusão
Salman Hersi
Membro desde: 01/14/20
333 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 846
