Ir para o conteúdo principal
Sony DSC-RX100MA Back Cover Replacement
O que você precisa
  1. Sony DSC-RX100MA Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Sony DSC-RX100MA Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Sony DSC-RX100MA Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA Back Cover Replacement: passo 2, imagem 1 %32 Sony DSC-RX100MA Back Cover Replacement: passo 2, imagem 2 %32 Sony DSC-RX100MA Back Cover Replacement: passo 2, imagem 3 %32
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
  3. Sony DSC-RX100MA Back Cover Replacement: passo 3, imagem 1 %32 Sony DSC-RX100MA Back Cover Replacement: passo 3, imagem 2 %32 Sony DSC-RX100MA Back Cover Replacement: passo 3, imagem 3 %32
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
  4. Sony DSC-RX100MA Back Cover Replacement: passo 4, imagem 1 %32 Sony DSC-RX100MA Back Cover Replacement: passo 4, imagem 2 %32
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA Back Cover Replacement: passo 5, imagem 1 %32 Sony DSC-RX100MA Back Cover Replacement: passo 5, imagem 2 %32 Sony DSC-RX100MA Back Cover Replacement: passo 5, imagem 3 %32
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA Back Cover Replacement: passo 6, imagem 1 %32 Sony DSC-RX100MA Back Cover Replacement: passo 6, imagem 2 %32
    • Remove the back cover
Conclusão
KC Egger
Membro desde: 02/10/17
315 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 21-1, Maness Winter 2017 Membro de Cal Poly, Team 21-1, Maness Winter 2017
CPSU-MANESS-W17S21G1
5 Membros
Autoria de 10 guias
1Comentário do guia
Hi! Two of the 1mm screws fell out of my camera from behind the display, where can I find new ones? I keep checking amazon and its kits of 750pcs+ and they don't seem like the right 1mm screws. Do you know where I can get some?
Victoria Gallardo - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 67
Ao todo: 3,889
