Introdução
How to disassemble the Sony DSC-HX50V to replace the lens.
O que você precisa
Remove the camera's battery.
Unscrew the three screws using a Phillips #00 screwdriver.
Unscrew the two screws on the left side of the camera.
Unscrew the remaining two screws on the opposing side of the camera.
With needle nose pliers, gently bend back the metal tab at the bottom of the click wheel PCB so that you can release this board from the upper metal tab. Fold it away to the right and slide apart the ribbon cable from this board and place aside.
Lift the LCD display away from the camera and again carefully remove two ribbon cables and place aside.
7 outras pessoas executaram este guia.
2 comentários
Thank You!
Could not have done it without this guide.
отлично! благодарю!
