Ir para o conteúdo principal
Sony Cybershot DSC-W830 Motherboard Replacement
O que você precisa
  1. Sony Cybershot DSC-W830 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Sony Cybershot DSC-W830 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W830 Motherboard Replacement: passo 2, imagem 1 %32
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: passo 3, imagem 1 %32 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: passo 3, imagem 2 %32 Sony Cybershot DSC-W830 Motherboard Replacement, Front/Back Panels: passo 3, imagem 3 %32
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W830 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W830 Motherboard Replacement: passo 5, imagem 1 %32 Sony Cybershot DSC-W830 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W830 Motherboard Replacement, Lens: passo 6, imagem 1 %32 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: passo 6, imagem 2 %32 Sony Cybershot DSC-W830 Motherboard Replacement, Lens: passo 6, imagem 3 %32
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
  7. Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: passo 7, imagem 1 %32 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: passo 7, imagem 2 %32 Sony Cybershot DSC-W830 Motherboard Replacement, LCD Screen: passo 7, imagem 3 %32
    • Lift the power button board up off of the daughterboard.
  8. Sony Cybershot DSC-W830 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the single Phillips #000 screw.
    • Use your hands to remove the blue daughterboard.
  9. Sony Cybershot DSC-W830 Motherboard Replacement: passo 9, imagem 1 %32 Sony Cybershot DSC-W830 Motherboard Replacement: passo 9, imagem 2 %32
    • Flip the camera around.
    • Remove the black and orange ribbon cables.
  10. Sony Cybershot DSC-W830 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Remove the two remaining ribbon cables.
    • Pull the motherboard from the camera.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 39
Ao todo: 691
