Ir para o conteúdo principal
Sony Cybershot DSC-W80 Lens Replacement
O que você precisa
  1. Sony Cybershot DSC-W80 Lens Replacement, Battery: passo 1, imagem 1 %32 Sony Cybershot DSC-W80 Lens Replacement, Battery: passo 1, imagem 2 %32
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 Lens Replacement: passo 2, imagem 1 %32
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: passo 3, imagem 1 %32 Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: passo 3, imagem 2 %32 Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: passo 3, imagem 3 %32
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 Lens Replacement: passo 4, imagem 1 %32
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 Lens Replacement: passo 5, imagem 1 %32 Sony Cybershot DSC-W80 Lens Replacement: passo 5, imagem 2 %32
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 Lens Replacement, Lens: passo 6, imagem 1 %32 Sony Cybershot DSC-W80 Lens Replacement, Lens: passo 6, imagem 2 %32 Sony Cybershot DSC-W80 Lens Replacement, Lens: passo 6, imagem 3 %32
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 521
