Ir para o conteúdo principal
Sony Cybershot DSC-T5 Plastic Screen Cover Replacement
O que você precisa
  1. Sony Cybershot DSC-T5 Plastic Screen Cover Replacement, Plastic Screen Cover: passo 1, imagem 1 %32 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement, Plastic Screen Cover: passo 1, imagem 2 %32
    • Push open the sliding cover to access screws.
  2. Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: passo 2, imagem 1 %32 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: passo 2, imagem 2 %32 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: passo 2, imagem 3 %32
    • Remove the screws in the red circles.
  3. Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: passo 3, imagem 1 %32 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: passo 3, imagem 2 %32 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: passo 3, imagem 3 %32
    • Remove the back cover panel from the rest of the camera.
  4. Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: passo 4, imagem 1 %32 Sony Cybershot DSC-T5 Plastic Screen Cover Replacement: passo 4, imagem 2 %32
    • Push the plastic cover out of the panel.
Conclusão
Uma outra pessoa concluiu este guia.
John Aust
Membro desde: 03/24/15
53 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-5, Vijaybhaskar Spring 2015 Membro de UMass Dartmouth, Team 4-5, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G5
Membros da 3
Autoria de 10 guias
Um comentário
omg thank you so much 😭😭😭 I have this old camera and it has some water drop in the plastic cover… I thought it was from the inside but it actually just fine😭 if I don't found out about this web I may lost some money to fix it at the store…
Nui Bờ - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 17
Duração total: 263
