Ir para o conteúdo principal
Sony Cyber-shot DSC-WX80 Motherboard Replacement
O que você precisa
  1. Sony Cyber-shot DSC-WX80 Motherboard Replacement, Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: passo 1, imagem 1 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement, Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: passo 1, imagem 2 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement, Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: passo 1, imagem 3 %32
    • Begin by removing all six #00 screws holding the outer chassis together.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 2, imagem 3 %32
    • At this point most of the parts in the camera should be free moving.
    • Take note of the small free moving flap near the battery port seen in the first of the three photos.
    • Now pry apart the top and bottom shell of the case.
  3. Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the two ribbon cables holding the LCD screen in place. Pull them directly out of the port they are plugged into.
    • Take care not to tear these ribbons as they are the communication network that your screen uses to operate.
    • Now that your LCD screen is detached you can pull it apart from the rest of the camera.
  4. Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 4, imagem 2 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 4, imagem 3 %32
    • The inner lining frame has an orange ribbon cable (circled in the image) that needs to be detached before it can be safely removed.
    • Carefully remove the inner frame lining as it can be fragile.
  5. Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 5, imagem 2 %32
    • After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
  6. Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 6, imagem 2 %32
    • To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports.
  7. Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-WX80 Motherboard Replacement: passo 7, imagem 2 %32
    • Finally to separate the motherboard from the base skeleton frame, one last silver screw and one ribbon cable need to be removed.
  8. Sony Cyber-shot DSC-WX80 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Now that your motherboard has been removed you can replace it!
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 762
