Ir para o conteúdo principal
Sony Cyber-shot DSC-WX80 Lens Replacement
O que você precisa
  1. Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: passo 1, imagem 1 %32 Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: passo 1, imagem 2 %32 Sony Cyber-shot DSC-WX80 Lens Replacement, LCD Screen: passo 1, imagem 3 %32
    • Begin by removing all six 40mm by 10mm black screws holding the outer frame together with the Phillips #00 screwdriver.
  2. Sony Cyber-shot DSC-WX80 Lens Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 2, imagem 3 %32
    • Remove the free-moving flap near the battery port and store in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Lens Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 3, imagem 3 %32
    • Remove the #00 screw from the right hand side (from the LCD screen side) which is adjacent to the master control dial.
    • Use a spudger or plastic opening tools to pry up the LCD screen and free the two metal tangs on the left side.
    • Lift up two more metal tabs held down by a thin red plastic strap on the right (master control dial) side. Reference the third image.
    • The thin red plastic strap is very fragile.
  4. Sony Cyber-shot DSC-WX80 Lens Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers, remove the blue ribbon from its connection located toward to the top right of the device.
    • Using a pair of tweezers, remove the gold ribbon from its connection located to the right of the removed blue ribbon.
    • Your LCD screen is now removed and you can replace it!
  5. Sony Cyber-shot DSC-WX80 Lens Replacement, Lens: passo 5, imagem 1 %32 Sony Cyber-shot DSC-WX80 Lens Replacement, Lens: passo 5, imagem 2 %32
    • After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
  6. Sony Cyber-shot DSC-WX80 Lens Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-WX80 Lens Replacement: passo 6, imagem 2 %32
    • To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports using tweezers.
    • Now that the Lens has been removed from the motherboard you can replace it!
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 37
Ao todo: 1,386
