Ir para o conteúdo principal
Sony Cyber-shot DSC-WX80 Battery Replacement
O que você precisa
  1. Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: passo 1, imagem 1 %32 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: passo 1, imagem 2 %32 Sony Cyber-shot DSC-WX80 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. Sony Cyber-shot DSC-WX80 Battery Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-WX80 Battery Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-WX80 Battery Replacement: passo 2, imagem 3 %32
    • Take note of the small free moving flap near the battery port seen in the first of the three photos. Be sure to store the free moving flap in a safe place.
    • Pry the front cover off gently. Use a plastic opening tool if available.
    • Now pry the back cover off gently, using a plastic opening tool if available.
  3. Sony Cyber-shot DSC-WX80 Battery Replacement: passo 3, imagem 1 %32
    • Access where the replacement battery will go indicated by the red square in the photo to your left
    • Now insert your new replacement battery
Conclusão
2 comentários
Why did you not just open the bottom battery door instead of pulling the camera apart?
Kat - Responder
I am also suprised to know that I should dis-assemble to replace battery. It maybe a joke.
Chung-Suh Ku - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 987
