Ir para o conteúdo principal
Sony Cyber-shot DSC-WX350 Lens Assembly Replacement
O que você precisa
  1. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 1 %32 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 2 %32 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 3 %32
    • Use the J00 screwdriver to take out the four 3mm black screws on the bottom and both sides of the camera.
  2. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 2, imagem 1 %32
    • On the bottom of the camera slide the button over to open the battery case. Inside the battery opening use the J00 screwdriver to take out the single 3mm black screw.
  3. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 3, imagem 1 %32
    • Use the J00 screwdriver to take out the single 3mm black screw on the left side of the camera .
  4. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to pry open the back cover off.
  5. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 5, imagem 1 %32
    • Use your fingers to slide out the controller wheel board 's lower end, then unhook the other end.
  6. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 6, imagem 1 %32
    • Take the LCD off by undoing the zif and sliding it out.
  7. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 7, imagem 2 %32
    • Once the LCD is off use the J00 screwdriver to take out the two 3mm silver screws. Once the screws are taken out pull off the piece with your fingers.
  8. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 8, imagem 3 %32
    • Now take out the 3 zifs by first opening the zif latch with your fingers and then sliding it out.
  9. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 9, imagem 1 %32
    • Carefully remove the lens assembly from the camera.
  10. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 10, imagem 2 %32
    • In order to access the CCD, loosen the 3 screws holding its metal lid.
    • In order to access the lens mechanics, take out the 4 3mm screws on the edge of the lid, then the single 3 mm screw next to the motor.
  11. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 11, imagem 1 %32
    • Carefully tear off the ribbon glued to the plastic.
  12. Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 12, imagem 1 %32 Sony Cyber-shot DSC-WX350 Lens Assembly Replacement: passo 12, imagem 2 %32
    • Pull out the cogwheel with the drive unit.
    • Now you can access the lens inner mechanics. You might wanna cover the CCD and the inner lens opening with tape to prevent dust from entering before you try to clean anything.
Conclusão
Joshua R Hammel
Membro desde: 05/22/17
234 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Wilson Summer 2017 Membro de IUPUI, Team S1-G1, Wilson Summer 2017
IUPUI-WILSON-SU17S1G1
Membros da 4
Autoria de 3 guias
2 comentários
Hi, I think on my sensor chip is some dust. Is it possible to clean that or is it one unit with lens? There is no picture about this detail….
Arno - Responder
Hi there, does anyone know who I could go to to fix the lens (replace them) on my Sony wx-350 camera Thank you!
Joshua O'Brien - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 53
Duração total: 4,477
