Ir para o conteúdo principal
Sony Cyber-shot DSC-WX350 Flash Assembly Replacement
O que você precisa
  1. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: passo 1, imagem 1 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: passo 1, imagem 2 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement, Flash Assembly: passo 1, imagem 3 %32
    • Remove 6 black Phillips 4 mm screws using the J00 head screwdriver tip from the sides and bottom of top cover.
  2. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 2, imagem 1 %32
    • Remove the black Phillips 4 mm screw using the J00 head screwdriver tip from inside the battery inclosure.
  3. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool to take back cover off. Then take out the LCD screen with your hand.
  4. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 4, imagem 1 %32
    • Now take the control wheel board out with your hand.
  5. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 5, imagem 1 %32
    • On the left side of the camera, pull the LCD off the back plate.
    • There will be a ZIF connector by the control wheel, release the connector and remove the LCD.
  6. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 6, imagem 2 %32
    • Remove silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal cover. Once done take the metal cover off with your hands.
  7. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 7, imagem 2 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 7, imagem 3 %32
    • Using your finger open take off the three zifs.
  8. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 8, imagem 2 %32
    • Use your hand to take out the lens assembly. Then take out the motherboard assembly with your hand.
  9. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 9, imagem 2 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 9, imagem 3 %32
    • Remove the silver Phillips 4 mm screws using the J00 head screwdriver tip from the metal piece and remove the 4mm screws from the metal piece lining the lens assembly hole.
  10. Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-WX350 Flash Assembly Replacement: passo 10, imagem 2 %32
    • Grab the top of the camera and take it out. Then grab the flash assembly and slide it out.
Conclusão
4 outras pessoas executaram este guia.
Matt Garthwaite
Membro desde: 05/22/17
125 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G1, Wilson Summer 2017 Membro de IUPUI, Team S1-G1, Wilson Summer 2017
IUPUI-WILSON-SU17S1G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 1,533
