Introdução
The control wheel is the button that is used to switch between pictures you are viewing and change options under "Settings". If you cannot move between different pictures or you are unable to move to different options in your settings when pushing those buttons, the control wheel may be broken. This guide will walk you through how to take apart the camera and easily replace the control wheel strip.
O que você precisa
Begin with the battery cover closed.
Remove 6 black Phillips 4 mm screws using the Ph000 head screwdriver tip from the bottom covering.
To remove the control wheel from its position, grab the bottom of the part and pivot to the side and away from the camera.
After the part is fully away from the camera, move the part downward and out. It should now be fully extended and able to bend at the band that is attached to the body.
Uma outra pessoa concluiu este guia.
