Ir para o conteúdo principal
Sony Cyber-shot DSC-WX220 Lens Assembly Replacement
O que você precisa
  1. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Slide the gray switch from lock to open position.
  2. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 2, imagem 2 %32
    • Pull down on the blue tab to release the battery.
  3. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: passo 3, imagem 1 %32 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: passo 3, imagem 2 %32 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Outer Case: passo 3, imagem 3 %32
    • Use a PH00 screwdriver to remove the five 3.5 mm screws.
    • Use a PH00 screwdriver to remove the two 2.5 mm screws.
  4. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 4, imagem 2 %32
    • Pry apart the case gently using a plastic opening tool.
  5. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement, Lens Assembly: passo 5, imagem 1 %32
    • Pry back the panel to the right of the screen using a plastic opening tool.
  6. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 6, imagem 1 %32
    • Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
  7. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 7, imagem 1 %32
    • Pull out the ZIF cable from the motherboard.
    • When removing the ZIF cable, pull it straight out to avoid damaging the cable.
  8. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 8, imagem 2 %32
    • Unpin the ZIF cable by lifting the cable towards the top of the camera while pulling up towards yourself.
    • Pull the ZIF cable out.
  9. Sony Cyber-shot DSC-WX220 Lens Assembly Replacement: passo 9, imagem 1 %32
    • Lift the lens out of the case.
    • Pull out the ZIF cable.
Conclusão
Kate Glazer
Membro desde: 03/20/18
621 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S6-G3, Baechle Spring 2018 Membro de IUPUI, Team S6-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 922
