Ir para o conteúdo principal
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
O que você precisa
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: passo 1, imagem 1 %32
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 2, imagem 1 %32
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: passo 3, imagem 1 %32 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: passo 3, imagem 2 %32 Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: passo 3, imagem 3 %32
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-WX100 Outer Casing Replacement: passo 5, imagem 2 %32
    • Use a plastic opening tool to gently release the two indicated tabs.
Conclusão
Matthew
Membro desde: 03/18/15
583 Reputação
Autoria de 4 guias
Equipe
Michigan Tech, Team 1-9, Lauer Spring 2015 Membro de Michigan Tech, Team 1-9, Lauer Spring 2015
MTU-LAUER-S15S1G9
Membros da 2
Autoria de 6 guias
Um comentário
Where I can buy the Outer Casing..¿??
ING CHARLY - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 797
