Ir para o conteúdo principal
Sony Cyber-shot DSC-WX100 Battery Replacement
  1. Sony Cyber-shot DSC-WX100 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Battery Replacement: passo 2, imagem 1 %32
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
Conclusão
Uma outra pessoa concluiu este guia.
Peter Prins
Membro desde: 03/19/15
262 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Ao todo: 1,291
