Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the Motherboard:
- The Motherboard is an integral part of the device and any improper handling can cause issues in other parts of the camera.
- Be cautious when removing ribbon wires.
- Be sure to keep track of all pieces that are taken apart.
O que você precisa
With plastic opening tool, gently pry loose the front panel.
Separate front panel from the camera housing.
Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
Remove the single 3.75 mm Phillips #000 screw from the base of the motherboard.
Use the tweezers. Move the thick red cable, attached to the secondary board, outside of its place in the camera housing.
Gently pull on the red/black wire in order to free the photo lens cylinder from the housing.
Remove the secondary board from its position and move it upward, out of the way.
