Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the five 4.0 mm Phillips #000 screws on the back panel.
Using the Spudger, remove the back panel from the device.
The loose piece circled in the picture will most likely fall off the camera housing.
Remove the two 2.15mm Phillips #000 screws from the circuit board.
Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
Lift the back panel and separate the LCD Screen by prying it up.
Remove the back panel.
Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
With plastic opening tool, gently pry loose the front panel.
Separate front panel from the camera housing.
Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
3 outras pessoas executaram este guia.
