Ir para o conteúdo principal
Sony Cyber-shot DSC-W800 Lens Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: passo 1, imagem 2 %32 Sony Cyber-shot DSC-W800 Lens Replacement, Button Board: passo 1, imagem 3 %32
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Lens Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W800 Lens Replacement: passo 2, imagem 2 %32
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Lens Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W800 Lens Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-W800 Lens Replacement: passo 3, imagem 3 %32
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 Lens Replacement, LCD Screen: passo 4, imagem 1 %32
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 Lens Replacement: passo 5, imagem 1 %32
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 Lens Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W800 Lens Replacement: passo 6, imagem 2 %32
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
  7. Sony Cyber-shot DSC-W800 Lens Replacement, Lens: passo 7, imagem 1 %32 Sony Cyber-shot DSC-W800 Lens Replacement, Lens: passo 7, imagem 2 %32
    • With plastic opening tool, gently pry loose the front panel.
    • Separate front panel from the camera housing.
  8. Sony Cyber-shot DSC-W800 Lens Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-W800 Lens Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-W800 Lens Replacement: passo 8, imagem 3 %32
    • Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
    • Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
    • Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
    • Be careful not to damage either of the ribbon wires.
Conclusão
3 outras pessoas executaram este guia.
Thomas Campo
Membro desde: 02/09/16
788 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 17-5, Blackwell Winter 2016 Membro de USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 34
Duração total: 4,123
