Introdução
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the Lens:
- The Lens is an integral part of the device and any improper handling can cause issues in other parts of the camera.
- Be cautious when removing ribbon wires.
- Be sure to keep track of all pieces that are taken apart.
Ferramentas
Peças
Nenhum componente especificado.
With plastic opening tool, gently pry loose the front panel.
Separate front panel from the camera housing.
Remove the lens housing by pushing it, from the front, through the housing and lifting it out.
Gently pull on the large ribbon wire (connecting the Lens housing to the motherboard via ZIF connector) with the tweezers.
Gently pull on the small ribbon wire (connecting the Lens housing to the motherboard) with the tweezers.
2 outras pessoas concluíram este guia.
