Ir para o conteúdo principal
Sony Cyber-shot DSC-W800 LCD Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: passo 1, imagem 2 %32 Sony Cyber-shot DSC-W800 LCD Screen Replacement, Button Board: passo 1, imagem 3 %32
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 LCD Screen Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W800 LCD Screen Replacement: passo 2, imagem 2 %32
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 LCD Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W800 LCD Screen Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-W800 LCD Screen Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
  4. Sony Cyber-shot DSC-W800 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32
    • Remove the four 3.75 mm Phillips #000 screws from the LCD back panel.
  5. Sony Cyber-shot DSC-W800 LCD Screen Replacement: passo 5, imagem 1 %32
    • Lift the back panel and separate the LCD Screen by prying it up.
    • Remove the back panel.
  6. Sony Cyber-shot DSC-W800 LCD Screen Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W800 LCD Screen Replacement: passo 6, imagem 2 %32
    • Gently pull on the ribbon wire disconnecting from the ZIF connector (connecting the LCD screen to the motherboard) with the tweezers.
    • Ribbon wires can be easily damaged.
Conclusão
3 outras pessoas executaram este guia.
Thomas Campo
Membro desde: 02/09/16
851 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 17-5, Blackwell Winter 2016 Membro de USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 37
Ao todo: 3,372
