Ir para o conteúdo principal
Sony Cyber-shot DSC-W800 Button Board Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: passo 1, imagem 2 %32 Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: passo 1, imagem 3 %32
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W800 Button Board Replacement: passo 2, imagem 2 %32
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W800 Button Board Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-W800 Button Board Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
Conclusão
3 outras pessoas executaram este guia.
Thomas Campo
Membro desde: 02/09/16
788 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 17-5, Blackwell Winter 2016 Membro de USF Tampa, Team 17-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G5
Membros da 5
Autoria de 5 guias
4 comentários
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - Responder
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - Responder
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 45
Duração total: 2,385
