Ir para o conteúdo principal
Sony Cyber-shot DSC-W730 Mother Board Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W730 Mother Board Replacement, Removing the Case: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement, Removing the Case: passo 1, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement, Removing the Case: passo 1, imagem 3 %32
    • Open the battery/memory card door and remove the 6 screws (.35cm) with a Philips 000 screwdriver. There will be two screws on the left and right sides, and two on the bottom.
  2. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 2, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 2, imagem 3 %32
    • Take off the front part of the case with a plastic opening tool.
  3. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 3, imagem 2 %32
    • Pull off the two silver side pieces on the left and right sides.
  4. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 4, imagem 2 %32
    • Remove the main back piece. It should easily lift off.
  5. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 5, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 5, imagem 3 %32
    • Unscrew the .45cm screw located on the upper right corner on the back of the camera. Once the screw is off, use the spudger and unclip the piece holding the top down on the upper left on the front of the camera. It should lift off with ease.
  6. Sony Cyber-shot DSC-W730 Mother Board Replacement, LCD Control Board: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement, LCD Control Board: passo 6, imagem 2 %32
    • Flip over the control board then use tweezers to pull out the ribbon connecting the circuit board to the motherboard.
  7. Sony Cyber-shot DSC-W730 Mother Board Replacement, LCD Screen: passo 7, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement, LCD Screen: passo 7, imagem 2 %32
    • Use tweezers to remove the ribbon that is connected from the LCD screen to the camera by pulling the part that is folded under, out.
  8. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 8, imagem 2 %32
    • Slide the right side of the LCD screen clockwise, which will push it off the camera. The rest of the screen should come off with it with ease.
  9. Sony Cyber-shot DSC-W730 Mother Board Replacement, Mother Board: passo 9, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement, Mother Board: passo 9, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement, Mother Board: passo 9, imagem 3 %32
    • After the screen is off, work the spudger under three clips to remove the metal plate.
  10. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 10, imagem 2 %32
    • After the clips are disengaged, lift off the metal cover.
  11. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 11, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 11, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 11, imagem 3 %32
    • Use the spudger and disengage the black plastic clip located on the bottom right of the camera facing the lens.
  12. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 12, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 12, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 12, imagem 3 %32
    • Flip the camera over, facing the bottom of the camera towards you. Then use the spudger to detach the plastic clip on the right, near where the LCD control board was.
  13. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 13, imagem 1 %32
    • Use the spudger and slide the plastic case over the mini USB port.
  14. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 14, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 14, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 14, imagem 3 %32
    • Use the spudger to disengage the plastic clip on the top of the camera.
  15. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 15, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 15, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 15, imagem 3 %32
    • Use the spudger and seperate each end of the metal piece. Once the speaker is free you can lift off the plastic frame.
  16. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 16, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 16, imagem 2 %32
    • Use tweezers to disconnect the ribbon located under the motherboard near the bottom of the camera.
  17. Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 17, imagem 1 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 17, imagem 2 %32 Sony Cyber-shot DSC-W730 Mother Board Replacement: passo 17, imagem 3 %32
    • Now with one hand located on the plastic skeleton and the other on the motherboard pull the motherboard to the left to disconnect the last ribbon.
Conclusão
Uma outra pessoa concluiu este guia.
Douglas Howe
Membro desde: 01/08/15
510 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 9-4, Blackwell Winter 2015 Membro de USF Tampa, Team 9-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 1,013
