Ir para o conteúdo principal
Sony Cyber-shot DSC-W730 Door Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W730 Door Replacement, Determining your Problem: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W730 Door Replacement, Determining your Problem: passo 1, imagem 2 %32 Sony Cyber-shot DSC-W730 Door Replacement, Determining your Problem: passo 1, imagem 3 %32
    • make sure your door slider tab is in good shape. If the tab is damaged you will need a door replacement.
    • make sure your tab notches are in good shape. If there is a problem with the notches then you will need to replace the front housing cover of the unit.
    • If your door closes but looks like the unit in the 3rd picture then your door is either bent and damaged or the unit may not be assembled properly.
  2. Sony Cyber-shot DSC-W730 Door Replacement, Removing Rear Housing Case: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W730 Door Replacement, Removing Rear Housing Case: passo 2, imagem 2 %32 Sony Cyber-shot DSC-W730 Door Replacement, Removing Rear Housing Case: passo 2, imagem 3 %32
    • Remove 6 external screws from the casing. They are all the same size. I recommend using Phillips screwdriver size PH000
    • Remove the rear casing. You may need a spudger to release the tab. The tab is a depression style tab
  3. Sony Cyber-shot DSC-W730 Door Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W730 Door Replacement: passo 3, imagem 2 %32
    • remove side panels
  4. Sony Cyber-shot DSC-W730 Door Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W730 Door Replacement: passo 4, imagem 2 %32 Sony Cyber-shot DSC-W730 Door Replacement: passo 4, imagem 3 %32
    • Remove side panels and then remove front cover
  5. Sony Cyber-shot DSC-W730 Door Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-W730 Door Replacement: passo 5, imagem 2 %32 Sony Cyber-shot DSC-W730 Door Replacement: passo 5, imagem 3 %32
    • Remove door rod
    • Remove door assembly and replace with new door. Reverse process to assemble unit
    • There is a little hole shown in the picture where the wire spring goes into.. make sure the wire spring is inserted into that hole or your door will not function.
Conclusão
Sales Cameraparts4you
Membro desde: 07/01/16
3.150 Reputação
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 183
