Introdução
Does your door have an issue closing fully? Is your door damaged? It is time to replace it! This guide will show you all the steps required to replace your camera door. It is simple and a good DIY project. Save your money and fix your camera yourself.
O que você precisa
make sure your door slider tab is in good shape. If the tab is damaged you will need a door replacement.
make sure your tab notches are in good shape. If there is a problem with the notches then you will need to replace the front housing cover of the unit.
If your door closes but looks like the unit in the 3rd picture then your door is either bent and damaged or the unit may not be assembled properly.
Remove 6 external screws from the casing. They are all the same size. I recommend using Phillips screwdriver size PH000
Remove the rear casing. You may need a spudger to release the tab. The tab is a depression style tab
