Ir para o conteúdo principal
Sony Cyber-shot DSC-W690 LCD screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W690 LCD screen Replacement, Battery: passo 1, imagem 1 %32
    • Locate the battery door.
  2. Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 2, imagem 1 %32
    • Open the battery lock by pushing the lid towards the inside and lifting.
  3. Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 3, imagem 2 %32
    • Remove the battery.
  4. Sony Cyber-shot DSC-W690 LCD screen Replacement, Front and Back Case: passo 4, imagem 1 %32
    • Remove the wrist strap from the camera.
  5. Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 5, imagem 2 %32
    • Remove all six 3 mm screws from the outside of the camera using a Phillips #00 screwdriver.
  6. Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 6, imagem 2 %32
    • Carefully pry the case apart by pulling the front and back sides in opposite directions.
  7. Sony Cyber-shot DSC-W690 LCD screen Replacement, LCD screen: passo 7, imagem 1 %32
    • Use spudger to delicately open wire contact.
  8. Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 8, imagem 1 %32
    • Gently push the LCD screen out of back case.
  9. Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 9, imagem 1 %32
    • Remove the button circuit board.
  10. Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-W690 LCD screen Replacement: passo 10, imagem 2 %32
    • Use spudger to pry apart the LCD screen from the support bracket.
Conclusão
Will Norris
Membro desde: 01/29/15
620 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 15-6, Shirley Winter 2015 Membro de Clemson, Team 15-6, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G6
5 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 892
