Ir para o conteúdo principal
Sony Cyber-shot DSC-W570 Case Cover Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: passo 1, imagem 1 %32
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 2, imagem 1 %32
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 3, imagem 1 %32
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 4, imagem 2 %32
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-W570 Case Cover Replacement: passo 5, imagem 2 %32
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
Conclusão
Uma outra pessoa concluiu este guia.
Zizheng Su
Membro desde: 01/21/15
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 9-1, Brown Winter 2015 Membro de USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 642
