Ir para o conteúdo principal
Sony Cyber-shot DSC-W55 Lens Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W55 Lens Replacement, Battery: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W55 Lens Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Lens Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W55 Lens Replacement: passo 2, imagem 2 %32
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W55 Lens Replacement, Back Case: passo 3, imagem 2 %32
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Lens Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W55 Lens Replacement: passo 4, imagem 2 %32
    • Remove the screw with a Phillips #00 screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Lens Replacement: passo 5, imagem 1 %32
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Lens Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W55 Lens Replacement: passo 6, imagem 2 %32
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
    Muchas gracias, muy claro!!
    Ruben - Responder
  7. Sony Cyber-shot DSC-W55 Lens Replacement, Front Case: passo 7, imagem 1 %32
    • Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
  8. Sony Cyber-shot DSC-W55 Lens Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-W55 Lens Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-W55 Lens Replacement: passo 8, imagem 3 %32
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Lens Replacement, Lens: passo 9, imagem 1 %32 Sony Cyber-shot DSC-W55 Lens Replacement, Lens: passo 9, imagem 2 %32
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Lens Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-W55 Lens Replacement: passo 10, imagem 2 %32
    • Gently pull the lens container out of the camera.
Conclusão
15 outras pessoas executaram este guia.
kkfong91
Membro desde: 10/11/10
344 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-20, Regan Fall 2010 Membro de Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
Membros da 5
Autoria de 18 guias
2 comentários
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Erwann Robin - Responder
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
agnelobarretto - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 98
Duração total: 21,972
