Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
This guide shows step by step instructions to remove the lens part of the camera.
  1. Slide the battery cover in the direction the arrow points. Pull the battery cover towards you.
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Flick the blue switch for the battery to pop out. Remove the battery from the camera.
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Using the Phillips #00 Screwdriver, remove the two screws from the caution panel. Remove that panel.
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Remove the screw with a Phillips #00 screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel). Remove that panel.
    • Remove the screw with a Phillips #00 screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Gently remove the back cover. It may be a bit stiff, so use some force to remove it. Proceed with caution.
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  7. Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
    • Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
  8. Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover. Gently remove the front cover. Put a little force to pop off the case. Proceed with caution.
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Flip the black secure locks off. Tweezers may be necessary. Detach the two  orange cables.
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Gently pull the lens container out of the camera. Gently pull the lens container out of the camera.
    • Gently pull the lens container out of the camera.
Conclusão
14 outras pessoas concluíram este guia.
kkfong91
Membro desde: 11/10/2010
320 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 9-20, Regan Fall 2010 Membro de Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 Membros
18 Guias de autoria
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Erwann Robin - Responder
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
agnelobarretto - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 20,155
