Ir para o conteúdo principal
Sony Cyber-shot DSC-W55 Back Case Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W55 Back Case Replacement, Battery: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W55 Back Case Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Back Case Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W55 Back Case Replacement: passo 2, imagem 2 %32
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Back Case Replacement, Back Case: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W55 Back Case Replacement, Back Case: passo 3, imagem 2 %32
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Back Case Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W55 Back Case Replacement: passo 4, imagem 2 %32
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Back Case Replacement: passo 5, imagem 1 %32
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Back Case Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W55 Back Case Replacement: passo 6, imagem 2 %32
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
Conclusão
kkfong91
Membro desde: 10/11/10
344 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-20, Regan Fall 2010 Membro de Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
Membros da 5
Autoria de 18 guias
Um comentário
Gracias a toda la gente de Ifixit, muy util esta aplicacion y muy buena gente!!.
Ruben - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 3,772
