Ir para o conteúdo principal
Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, LCD Screen: passo 1, imagem 1 %32
    • Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
  2. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: passo 2, imagem 2 %32
    • Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
    • There are five screws on the bottom of the camera and two on the side.
    • If the screws are stripped, visit the Removing a Stripped Screw Guide.
  3. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 3, imagem 2 %32
    • Pry open the screen frame using a plastic opening tool.
    • It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
  4. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 4, imagem 2 %32
    • Using the screw driver, unscrew the one screw on the control panel board.
  5. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 5, imagem 1 %32
    • Gently unplug the control panel from the motherboard outlet.
  6. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 6, imagem 2 %32
    • Using your hands, pry open the LCD screen from the metal board.
    • Gently unplug the LCD screen from the motherboard.
  7. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: passo 7, imagem 1 %32 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: passo 7, imagem 2 %32
    • Remove the screws from the metal board using the Phillips #00 screwdriver.
    • Pop apart the metal board using the plastic opening tool.
    • Peel apart the black tape from the flash bulb.
    • Avoid touching the bulb as it will burn or shock if touched.
  8. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 8, imagem 2 %32 Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 8, imagem 3 %32
    • Pry open the remaining covers of the camera using the plastic opening tool.
    • Some parts may fall out during this process.
  9. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 9, imagem 1 %32
    • Unscrew the one screw from the motherboard.
    • Disconnect the two links from the camera unit to the motherboard.
  10. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: passo 10, imagem 1 %32
    • Pop out the lens zoom unit from the frame by using either your thumb or an opening tool.
Conclusão
4 outras pessoas executaram este guia.
kyle
Membro desde: 02/05/15
424 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 31
Duração total: 1,296
