Ir para o conteúdo principal
Sony Cyber-shot DSC-W510 LCD Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W510 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
  2. Sony Cyber-shot DSC-W510 LCD Screen Replacement, Unscrew: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W510 LCD Screen Replacement, Unscrew: passo 2, imagem 2 %32
    • Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
    • There are five screws on the bottom of the camera and two on the side.
    • If the screws are stripped, visit the Removing a Stripped Screw Guide.
  3. Sony Cyber-shot DSC-W510 LCD Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W510 LCD Screen Replacement: passo 3, imagem 2 %32
    • Pry open the screen frame using a plastic opening tool.
    • It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
  4. Sony Cyber-shot DSC-W510 LCD Screen Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W510 LCD Screen Replacement: passo 4, imagem 2 %32
    • Using the screw driver, unscrew the one screw on the control panel board.
  5. Sony Cyber-shot DSC-W510 LCD Screen Replacement: passo 5, imagem 1 %32
    • Gently unplug the control panel from the motherboard outlet.
  6. Sony Cyber-shot DSC-W510 LCD Screen Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W510 LCD Screen Replacement: passo 6, imagem 2 %32
    • Using your hands, pry open the LCD screen from the metal board.
    • Gently unplug the LCD screen from the motherboard.
Conclusão
3 outras pessoas executaram este guia.
kyle
Membro desde: 02/05/15
424 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 2,038
