Ir para o conteúdo principal
Sony Cyber-shot DSC-W50 Front Case Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: passo 1, imagem 2 %32 Sony Cyber-shot DSC-W50 Front Case Replacement, Front Case: passo 1, imagem 3 %32
    • Remove the rightmost screw on the bottom of the camera with the screwdriver.
    • Remove the bottom left screw with the screwdriver.
    • Remove the top left screw with the screwdriver.
  2. Sony Cyber-shot DSC-W50 Front Case Replacement: passo 2, imagem 1 %32
    • Flip the camera over to expose its right side.
    • Remove the screw with the screwdriver.
  3. Sony Cyber-shot DSC-W50 Front Case Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W50 Front Case Replacement: passo 3, imagem 2 %32
    • Flip the camera to expose the left side with the wrist strap.
    • Remove the top screw with the screwdriver.
    • Remove the bottom screw with the screwdriver.
  4. Sony Cyber-shot DSC-W50 Front Case Replacement: passo 4, imagem 1 %32
    • Lift the side panel of the camera up to release the front case.
  5. Sony Cyber-shot DSC-W50 Front Case Replacement: passo 5, imagem 1 %32
    • Lift the front case up gently to remove it completely.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 627
