Ir para o conteúdo principal
Sony Cyber-shot DSC-W5 Lens Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W5 Lens Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 Lens Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 2, imagem 2 %32
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 Lens Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 3, imagem 2 %32
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 Lens Replacement, LCD Screen: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement, LCD Screen: passo 4, imagem 2 %32
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 Lens Replacement: passo 5, imagem 1 %32
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 Lens Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 6, imagem 2 %32
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 Lens Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 7, imagem 2 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 7, imagem 3 %32
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
  8. Sony Cyber-shot DSC-W5 Lens Replacement, Speaker: passo 8, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement, Speaker: passo 8, imagem 2 %32
    • Remove the two screws holding down the steel back plate.
    • Remove steel back plate.
  9. Sony Cyber-shot DSC-W5 Lens Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 9, imagem 2 %32
    • Now remove the plastic plate that covers the motherboard.
  10. Sony Cyber-shot DSC-W5 Lens Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 10, imagem 2 %32
    • Warning: Electric Shock From this point on, hold the camera by the chrome edges ONLY. Capacitors store electric charge even if the batteries are removed.
    • Remove the blue cable.
  11. Sony Cyber-shot DSC-W5 Lens Replacement: passo 11, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 11, imagem 2 %32
    • Disconnect the flash cable (black and white wires) before completely removing the front case.
    • Gently start to remove the case.
    • Once the cable is free, set aside the front case.
  12. Sony Cyber-shot DSC-W5 Lens Replacement: passo 12, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement: passo 12, imagem 2 %32
    • The speaker should now be clearly seen on the underside of the camera.
    • Gently unplug the speaker from the motherboard.
    • Replace the speaker.
  13. Sony Cyber-shot DSC-W5 Lens Replacement, Battery Terminal: passo 13, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement, Battery Terminal: passo 13, imagem 2 %32
    • Remove the orange cable connecting the battery terminal to the motherboard.
  14. Sony Cyber-shot DSC-W5 Lens Replacement: passo 14, imagem 1 %32
    • The battery terminal is now free from the board and can be slid out.
  15. Sony Cyber-shot DSC-W5 Lens Replacement, Lens: passo 15, imagem 1 %32 Sony Cyber-shot DSC-W5 Lens Replacement, Lens: passo 15, imagem 2 %32 Sony Cyber-shot DSC-W5 Lens Replacement, Lens: passo 15, imagem 3 %32
    • Detach two cables that go from the motherboard to the lens.
    • Remove lens.
Conclusão
7 outras pessoas executaram este guia.
Thomas
Membro desde: 04/14/10
133 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 15-50, Garner Spring 2010 Membro de Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
Membros da 5
Autoria de 12 guias
Um comentário
Ifixit it's so awesome... For a guy who loves to bring things apart but is scared of how to do it ifixit is wonderful
ogunkayodesamuel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Duração total: 21,467
