Ir para o conteúdo principal
Sony Cyber-shot DSC-W290 casing Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W290 casing Replacement, Battery: passo 1, imagem 1 %32
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 casing Replacement: passo 2, imagem 1 %32
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W290 casing Replacement, Outer Casing: passo 3, imagem 2 %32
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 casing Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W290 casing Replacement: passo 4, imagem 2 %32 Sony Cyber-shot DSC-W290 casing Replacement: passo 4, imagem 3 %32
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 casing Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-W290 casing Replacement: passo 5, imagem 2 %32 Sony Cyber-shot DSC-W290 casing Replacement: passo 5, imagem 3 %32
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 casing Replacement: passo 6, imagem 1 %32
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 casing Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-W290 casing Replacement: passo 7, imagem 2 %32
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 casing Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-W290 casing Replacement: passo 8, imagem 2 %32
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 casing Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-W290 casing Replacement: passo 9, imagem 2 %32
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 casing Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-W290 casing Replacement: passo 10, imagem 2 %32
    • This is what your camera should look like now that you have removed the casing from all sides.
Conclusão
Uma outra pessoa concluiu este guia.
Evan Mayer
Membro desde: 10/05/10
318 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 7-54, Amido Fall 2010 Membro de Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,804
