Ir para o conteúdo principal
Sony Cyber-shot DSC-W290 Flash Bulb Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Battery: passo 1, imagem 1 %32
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 2, imagem 1 %32
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Outer Casing: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Outer Casing: passo 3, imagem 2 %32
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 4, imagem 2 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 4, imagem 3 %32
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 5, imagem 2 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 5, imagem 3 %32
    • Turn the camera so the right side faces you.
  6. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 6, imagem 1 %32
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 7, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 7, imagem 2 %32
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 8, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 8, imagem 2 %32
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 9, imagem 2 %32
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 10, imagem 2 %32
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, LCD Assembly: passo 11, imagem 1 %32
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 12, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 12, imagem 2 %32
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
  13. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 13, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 13, imagem 2 %32
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 14, imagem 1 %32
    • Pull the LCD and its casing away from the rest of the camera.
  15. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb Assembly: passo 15, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb Assembly: passo 15, imagem 2 %32
    • Turn the camera so the back is facing you.
    • Remove the 2.5mm Philips #0 screw at the top of the camera.
  16. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 16, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 16, imagem 2 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 16, imagem 3 %32
    • Tilt top casing up and towards you.
    • Carefully remove the right ribbon-wire from the top camera panel by pulling where the wire connects to the top.
    • Make sure to hold the camera with your thumb on the white square to ensure the ribbon-wire is not disconnected from the motherboard.
    • Carefully remove the left ribbon-wire from the top camera panel by pulling where the wire connects to the top.
  17. Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb: passo 17, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb: passo 17, imagem 2 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement, Flash Bulb: passo 17, imagem 3 %32
    • Pull the top of the camera off and turn it so the bottom is facing you.
    • Desolder the three connections from the bulb to the small circuit board.
    • Remove the excess solder using your soldering iron and desoldering wick.
  18. Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 18, imagem 1 %32 Sony Cyber-shot DSC-W290 Flash Bulb Replacement: passo 18, imagem 2 %32
    • Gently wiggle the flash bulb to remove it from the joints.
    • It may be necessary to use the soldering iron to heat up the joints as you pull it off.
Conclusão
William Schill
Membro desde: 10/04/10
222 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 7-54, Amido Fall 2010 Membro de Cal Poly, Team 7-54, Amido Fall 2010
CPSU-AMIDO-F10S7G54
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 6,760
