Ir para o conteúdo principal
Sony Cyber-shot DSC-W230 LCD Display Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, Separating Camera and Display: passo 1, imagem 1 %32 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, Separating Camera and Display: passo 1, imagem 2 %32
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  2. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 2, imagem 1 %32 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 2, imagem 2 %32
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  3. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 3, imagem 1 %32 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 3, imagem 2 %32 Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 3, imagem 3 %32
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
  4. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement, LCD Display Screen: passo 4, imagem 1 %32
    • Using a flat head screw driver gently pry up the tab securing the ribbon cable from the display screen to the camera sensor and battery housing.
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing
    • Following the same procedure as above, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
  5. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 5, imagem 1 %32
    • The LCD display screen is now removed from the camera sensor and battery housing.
    • The main camera controls are now removed from the camera sensor and battery housing.
  6. Sony Cyber-shot DSC-W230 LCD Display Screen Replacement: passo 6, imagem 1 %32
    • Unsnap LCD display screen from its mount by unsnapping it from the display screen using your finger nail.
    • Now the new LCD screen can be installed.
Conclusão
Michael Henry
Membro desde: 03/09/12
21 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 2-3, Benson Spring 2012 Membro de Clemson, Team 2-3, Benson Spring 2012
CLEM-BENSON-S12S2G3
Membros da 3
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 26
Duração total: 3,768
