Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Follow Step 16 and 17 from the LCD Screen pre-requisite. LCD Repair Guide
Using a spudger, wedge the flat tipped end between the black bar and the circuit board.
Carefully lift the black bar into the vertical position.
Repeat first two bullet points for the circuit board port directly to the left of the one shown in this picture.
Use tweezers to carefully pull the electrical ribbons from the circuit board ports.
