Ir para o conteúdo principal
Sony Cyber-shot DSC-W150 Back Casing Replacement
O que você precisa
  1. Sony Cyber-shot DSC-W150 Back Casing Replacement, Back Casing: passo 1, imagem 1 %32
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 2, imagem 1 %32
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
  3. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 3, imagem 1 %32
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
  4. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 4, imagem 1 %32
    • On the left side of the camera, remove the two silver screws using the screwdriver.
  5. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 5, imagem 1 %32
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
  6. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 6, imagem 1 %32
    • After detaching the back cover, carefully pull it off.
  7. Sony Cyber-shot DSC-W150 Back Casing Replacement: passo 7, imagem 1 %32
    • The back cover should now be separated from the camera.
Conclusão
4 outras pessoas executaram este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 4,966
