Introdução
This repair guide will instruct you to disassemble the Sony Cyber-shot DSC W150 to replace a scratched or broken back casing. A screwdriver will remove a total of 8 screws to remove the back casing successfully. Once the screws are removed, you can use your hands to pull apart the back casing.
O que você precisa
4 outras pessoas executaram este guia.
