Ir para o conteúdo principal
Sony Cyber-shot DSC-TX55 LCD Screen Replacement
O que você precisa
  1. Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Sony Cyber-shot DSC-TX55 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • Slide open the battery cover in the direction that the arrows on device are pointing.
    • Flip the blue battery lock to eject the battery.
    • Remove the battery from the device.
  2. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 2, imagem 1 %32
    • Using your Phillips #00 screwdriver, remove all four 0.3 cm screws that are located on both ends, as well as the bottom of your Cyber-Shot.
    • Make sure that your screws are placed on a flat, still surface so they do not roll away.
  3. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 3, imagem 1 %32
    • Gently pull away the back end of the camera where the LCD screen is located.
    • Remove the metal frame that is located around the LCD screen.
  4. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 4, imagem 1 %32
    • Remove the front cover.
  5. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 5, imagem 1 %32
    • Gently remove the lens from the device.
    • The lens will hang on by the orange strips, be careful not to tug on the lens.
  6. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 6, imagem 2 %32
    • Gently slide the LCD screen using very light pressure to the right until it pops open.
  7. Sony Cyber-shot DSC-TX55 LCD Screen Replacement: passo 7, imagem 1 %32
    • The LCD screen will open to the right.
    • Remove the orange tab from the device.
Conclusão
Megan East
Membro desde: 10/13/15
555 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 2,360
