Ir para o conteúdo principal
Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement
O que você precisa
  1. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: passo 1, imagem 1 %32 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: passo 1, imagem 2 %32 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement, OLED/LCD Assembly: passo 1, imagem 3 %32
    • Remove the battery
    • Remove the five 2.5mm Philips #0 screws.
    • Remove the one 2.5mm Philips #0 screw inside the HDMI case.
  2. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 2, imagem 1 %32
    • Gently work and pull the front cover off of the camera
  3. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 3, imagem 1 %32
    • Gently pull and disconnect the ribbon cable connecting the front cover to the main body
  4. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 4, imagem 1 %32 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 4, imagem 2 %32 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    iSesamo Opening Tool
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry off the cover of the OLED/LCD assembly.
    • Take care of the tab/clip at the bottom, it can be a little tricky.
    • iSesamo Opening Tool is highly recommended
  5. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 5, imagem 1 %32 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 5, imagem 2 %32
    • Remove the copper phillips screw holding the HDMI mounting plate and detach the mounting plate.
  6. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 6, imagem 1 %32 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 6, imagem 2 %32 Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 6, imagem 3 %32
    $9.99
    • Using an iSesamo Opening Tool, Spudger, or flat dull opening tool, gently pry the OLED/LCD assembly from the adhesive strip on the main body.
    • Note: where the adhesive strip is located.
    • Turn the device over and remove the clear tape and black tape.
    • Important: Save the clear and black tape, they will be used for the replacement unit.
  7. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 7, imagem 1 %32
    • Gently pull the small flat ribbon cable from the main body
    • In order to disconnect the large flat ribbon cable, you need to flip up the black ribbon clamp located on the main body where the socket is located
  8. Sony Cyber-shot DSC-TX100V OLED/LCD Assembly Replacement: passo 8, imagem 1 %32
    • Reattach new display, and reconnect all components
    • Test camera to ensure the new screen is working
    • Congrats!
Conclusão
Uma outra pessoa concluiu este guia.
Tim
Membro desde: 03/12/12
2.217 Reputação
Autoria de 2 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 4,851
