Introdução
This guide will allow the user to access the motherboard for installation, replacement, or removal.
O que você precisa
The battery cover is located on the right side of the camera.
Slide the cover to expose the battery.
Remove screws from outside of camera. There are 6 screws total.
3 screws on underside.
1 screw on right side, near battery cover.
2 screws on left side.
These two screws hold in the AV port.
Use Phillips screwdriver to remove screws.
3 outras pessoas executaram este guia.
