Ir para o conteúdo principal
Sony Cyber-shot DSC-T9 LCD Replacement
O que você precisa
  1. Sony Cyber-shot DSC-T9 LCD Replacement, Battery: passo 1, imagem 1 %32
    • The battery cover is located on the right side of the camera.
    • Slide the cover to expose the battery.
  2. Sony Cyber-shot DSC-T9 LCD Replacement: passo 2, imagem 1 %32
    • Ensure that the battery lines up properly with the slot in the camera.
    • Slide battery in.
    • Slide cover closed.
    • Battery not shown
  3. Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: passo 3, imagem 1 %32 Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: passo 3, imagem 2 %32 Sony Cyber-shot DSC-T9 LCD Replacement, Front Cover: passo 3, imagem 3 %32
    • Remove screws from outside of camera. There are 6 screws total.
    • 3 screws on underside.
    • 1 screw on right side, near battery cover.
    • 2 screws on left side.
  4. Sony Cyber-shot DSC-T9 LCD Replacement: passo 4, imagem 1 %32
    • Use screwdriver to remove screws.
  5. Sony Cyber-shot DSC-T9 LCD Replacement: passo 5, imagem 1 %32
    • Gently pull the front cover off of the main camera.
    • All of the inner parts of the camera are attached to the back screen.
  6. Sony Cyber-shot DSC-T9 LCD Replacement: passo 6, imagem 1 %32
    • The front cover is now removed from the camera and the internal hardware is now exposed.
  7. Sony Cyber-shot DSC-T9 LCD Replacement, Back Cover: passo 7, imagem 1 %32
    • This is the camera without the front cover.
  8. Sony Cyber-shot DSC-T9 LCD Replacement: passo 8, imagem 1 %32
    • Remove tripod piece located at the bottom of the camera. This piece should slide out with ease.
  9. Sony Cyber-shot DSC-T9 LCD Replacement: passo 9, imagem 1 %32 Sony Cyber-shot DSC-T9 LCD Replacement: passo 9, imagem 2 %32 Sony Cyber-shot DSC-T9 LCD Replacement: passo 9, imagem 3 %32
    • Slide open the top panel. This is located on the top of the camera, where the power button and shutter button are.
  10. Sony Cyber-shot DSC-T9 LCD Replacement: passo 10, imagem 1 %32 Sony Cyber-shot DSC-T9 LCD Replacement: passo 10, imagem 2 %32 Sony Cyber-shot DSC-T9 LCD Replacement: passo 10, imagem 3 %32
    • Pull apart the inner hardware from the back case by prying on the left side.
  11. Sony Cyber-shot DSC-T9 LCD Replacement: passo 11, imagem 1 %32
    • Remove the back cover.
  12. Sony Cyber-shot DSC-T9 LCD Replacement: passo 12, imagem 1 %32
    • The back cover is now removed from the internal hardware.
  13. Sony Cyber-shot DSC-T9 LCD Replacement, LCD: passo 13, imagem 1 %32
    • Use the spudger to pry the LCD from the camera.
  14. Sony Cyber-shot DSC-T9 LCD Replacement: passo 14, imagem 1 %32
    • The LCD is now removed from the camera, although attached by a ribbon at the bottom of the camera.
  15. Sony Cyber-shot DSC-T9 LCD Replacement: passo 15, imagem 1 %32 Sony Cyber-shot DSC-T9 LCD Replacement: passo 15, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Flip camera to other side.
    • Use tweezers to peel off black sticker, located in middle of the motherboard.
  16. Sony Cyber-shot DSC-T9 LCD Replacement: passo 16, imagem 1 %32 Sony Cyber-shot DSC-T9 LCD Replacement: passo 16, imagem 2 %32
    • Use pry stick to pop out LCD connector ribbon, also called the ZIF connector.
  17. Sony Cyber-shot DSC-T9 LCD Replacement: passo 17, imagem 1 %32
    • The LCD is now removed from the camera.
Conclusão
Stephannie Allen
Membro desde: 03/11/13
276 Reputação
Autoria de 10 guias
Equipe
Clemson, Team 13-1, Benson Spring 2013 Membro de Clemson, Team 13-1, Benson Spring 2013
CLEM-BENSON-S13S13G1
4 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 1,755
